chengp ®   05-Apr-2015 22:04
Alfa Laval P615 Separator (Instruction manual | Spare parts catalogue)
Year: 2009
Author: Alfa Laval
Publisher: Alfa Laval Tumba AB Sweden
Pages count: 232
Description: The P 615 is a high-speed centrifugal separator intended for marine and land applications. It is specifically designed for cleaning of mineral oils
from water and solid particles (sludge). The cleaned oil is discharged continuously, while the sludge is discharged at intervals.
The separator handles the following types of lubricating oils and low viscosity fuel oils:
• Distillate, viscosity 1,5 - 5,5 cSt/40 °C
• Marine diesel oil, viscosity 13 cSt/40 °C
• Intermediate fuel oil and heavy fuel oil (viscosity 30-380 cSt/50 °C)
• Lubricating oil of R & O type, detergent or steam turbine.
The separator can be operated either as a purifier or as a clarifier. When operated as a purifier the separator discharges the separated water continuously.
When the oil contains only small amounts of water the separator is operated as a clarifier, discharging the water together with the solid particles.
The separator has to be installed together with devices for control of its operation.
1 Safety Instructions..................................................... .7
1.1 Warning signs in text ............................................. 12
1.2 Environmental issues ............................................ 13
1.3 Requirements of personnel.................................. 14
2 Read this first & Separator Basics .............. .15
2.1 Read This First......................................................... 16
2.2 Design and function ............................................... 18
2.3 Definitions ................................................................. 26
3 Service Instructions............................................... .27
3.1 Periodic maintenance............................................ 28
3.2 Maintenance Logs................................................... 31
3.3 Check points at Intermediate Service............. 36
3.4 Check points at Major Service ........................... 48
3.5 3-year service........................................................... 51
3.6 Lifting instructions ................................................. 52
3.7 Cleaning ..................................................................... 53
3.8 Oil change.................................................................. 56
3.9 Vibration..................................................................... 58
3.10 General directions .................................................. 60
4 Dismantling/Assembly........................................... .65
4.1 Inlet/outlet and bowl .............................................. 68
4.2 Bowl spindle and frame ........................................ 86
4.3 Friction coupling ................................................... 100
4.4 Flat belt and tightener......................................... 107
4.5 Oil filling device..................................................... 112
4.6 Water tank............................................................... 113
4.7 Brake......................................................................... 113
4.8 Frame feet ............................................................... 115
5 Technical Reference.............................................117
5.1 Product description.............................................. 118
5.2 Technical data ....................................................... 119
5.3 Connection list....................................................... 120
5.4 Basic size drawing................................................ 122
5.5 Interface description ........................................... 124
5.6 Water quality .......................................................... 132
5.7 Lubricants................................................................ 133
5.8 Drawings .................................................................. 143
5.9 Storage and installation ..................................... 159
577461-02
5.10 Protection and storage of goods...................... 160
6 Operating..................................................................... .169
6.1 Operating routine ..................................................170
6.2 Before first Start.................................................... 170
6.3 Start after a service ............................................. 172
6.4 After Safety Stop................................................... 179
1 Read this Þrst 5
1.1 General information 6
1.2 Translation list 9
2 Machine bottom part 12
2.1 Oil Þlling device 14
2.2 Brake 16
3 Separator bowl 18
4 Inlet and outlet device 20
5 Motor mounting assembly, 50/60
Hz 22
5.1 Friction coupling, 50/60 Hz 24
5.2 Belt tightener 26
6 Motor mounting assembly, NEMA
standard 28
6.1 Friction coupling, 60 Hz NEMA standard 30
7 Set of plates 32
8 Gravity disc 34
9 Vibration monitoring unit 36
10 Set of tools 38
11 Interlocking switch 40
12 Intermediate service kit 42
13 Major service kit 44
14 3-years service kit 46
15 Tool box 48
16 Cross reference list 50
Alfa Laval P 615
Download [10 KB]
Separator HH-160 - Hutchison Hayes / Maintenance, Operation and Parts Manual [PDF]
Samgong-Mitsubishi Selfjector Genius-Series / Instruction & Maintenance Manual / Part 1,2,3 [PDF]
Alfa Laval MAB 103B-24 Separator Instruction Manual - Alfa Laval Tumba AB [2019, PDF]
Alfa-Laval Centufugal Type OWS - Alfa-Laval [2012, PDF]
Alfa Laval S966 Separator Instruction Manual - Alfa Laval Tumba AB [2017, PDF]
Mitsubishi Self Ejector Genius-Series (Instruction/Maintenance Manual) - Mitsubishi [PDF]
GEA Westfalia Mineral oil centrifuge with self-cleaning bowl OSE-5-91-037 - GEA Westfalia [2014,…
Wartsila Engines W20, W26, W32, W38, W46, W50, W64 Etc / Project guide for marine applications…
SA 846 Separator (Purifier) System - Alfa Laval-Sweden [2006, PDF]
Alfa Laval Clarifier and Purifier for Lube Oil System [2017, MP4]
The time now is: Today 19:21
