gillnumil ®   17-Nov-2020 20:05
A Guide for Passage Planning for the Transit of The Straits of Malacca and Singapore -For vessels of draughts of less than 12 metres
Year: 1998
Author: SIGTTO
Publisher: Society of International Gas Tanker & Terminal Operators Ltd
Pages count: 103
Description: The intention of this ‘Guide to Passage Planning’ is as a guide to information that is required to compile an effective, individual ship plan from the One Fathom Bank to the Horsburgh and from the Horsburgh to the One Fathom Bank. It is basically in the form of ‘Passage Notes’ that may be used by the navigator to supplement information either at hand or in use. In general, following present recommended practices much of the information should be included on the chart as a central point for information.
A guide for passage planning for the transit of the malacca and singapore - Sigtto.PDF
tony_aug2   21-Jan-2021 08:17
pls publish latest passage planning guide lines if you have for Singapore
ISGINTT International Safety Guide for Inland Navigation Tank-barges and Terminals - CCNR/OCIMF…
Passage Planning Guide – Straits of Malacca & Singapore (SOMS)
Information technical Papers and Guides - SIGTTO [2025, PDF]
Bulk Liquified Gas by Sea: The Early Years - Robin Gray [2004, PDF]
SIGTTO Newsletters: 2012 to 2023 - SIGTTO [2023, PDF]
Marine Terminal Survey Guidelines Chemical Gas and Oil Terminals - OCIMF [1995, PDF]
Passage Planning Guide - Malacca and Singapore Straits - 3rd Ed - Unknown [2011, PDF]
Simulation Information Paper - SIGTTO [2010, PDF]
Ship Vetting and its Application to LNG - SIGTTO [2004, PDF]
Northern Sea Route Navigation-Best Practices and Challenges - Oil Companies International Marine…
The time now is: Today 05:24
